previous call: Developers's call 27.09.2021
Today was another busy call with many topics. First, we want to welcome @j.breuer to the CADET developer’s team who will be working on implementing DG in CADET. ![]()
LDF Isotherm Models
- WIP
- Initial tests were found to confirm functionality; proper tests will follow (see below).
Unit tests
@all: We should set a date to write unit tests and/or integration tests for some of the recent projects. This includes tests for:
- LDF
- MCT
- Dynamic Flow / Reverse Flow
Conda-forge
Issues with Windows builds were fixed by :
- Using sequential blas in build.bat (@j.rao)
- Including
IteratorinModelSystemImpl.cpp(@w.heymann)
Next steps:
- make CADET release 4.2.1/4.3.0
- ping conda-forge team again to merge into main repository
C interface to libcadet
Before proceeding, we should determine the dimensionality of the solution outputs of different unit operations (see here). For this pupose, @j.hassan will create a table that lists the current state.
CADET-Process
- Published on test.pypi; install with
pip install --index-url https://test.pypi.org/simple/ --extra-index-url https://pypi.org/simple/ CADET-Process(installs CADET-Process from test.pypi.org and all dependencies from the ‘real’ pypi.org). - Proper release on pypi will follow shortly.
- Examples need to be updated.
